- CMarinLiviu
- 17 mesaje
- din 29 Jan 2018
- Astra 2006 Z18XER
- Arges
CMarinLiviu
- Mesaje scrise: 17
- Masina: Astra 2006 Z18XER
- Cont inregistrat: 29 Jan 2018
- cutienoua
- 326 mesaje
- din 28 Mar 2016
- Astra 2009 Y17DT
- Mehedinti
cutienoua
- Mesaje scrise: 326
- Masina: Astra 2009 Y17DT
- Cont inregistrat: 28 Mar 2016
se poate,dar eu unul sunt fan aftermarket. am gasit niste instructiuni in engleza dar posibil sa le gasesti si traduse:
1. Update your CD70 to latest firmware, i.e. 10/10/2007. (15 minutes)
Addition information: To update the firmware you will need an update disc.
This disc can be acquired from Vx dealer (at about £5 ?) or borrow from your friend.
It's a job of once and for all and you will not need that ever.
2. Find A Tech2 or Vauxcom or similar product to activate your aux-in in the software.
A new "Aux" menu will be appeared just as shown in the picture after a successful activation.
Audio pass (carpass) is NOT required. (2 minute)
3. Open your CD70 and solder some components (which are included by this auction) to the mainboard (1-2 hour).
4. Insert 3 wires with cramp (included) to the quadlock connector (Car to CD70 connector), then connect these wires to a jack socket.
The jack socket can be purchased from everywhere(e.g. maplin, order code:FK03D), or you can buy a tray with auxin socket from dealer (part number is in the guide,
- AlexDmi
- 537 mesaje
- din 25 Feb 2009
- Vectra 2007 Z20NET
AlexDmi
- Mesaje scrise: 537
- Masina: Vectra 2007 Z20NET
- Cont inregistrat: 25 Feb 2009
- CMarinLiviu
- 17 mesaje
- din 29 Jan 2018
- Astra 2006 Z18XER
- Arges
CMarinLiviu
- Mesaje scrise: 17
- alexx1402
- 1,753 mesaje
- din 16 Aug 2010
- Astra 2017 B16DTH
alexx1402
- Mesaje scrise: 1,753
- Masina: Astra 2017 B16DTH
- Cont inregistrat: 16 Aug 2010
- cutienoua
- 326 mesaje
- din 28 Mar 2016
- Astra 2009 Y17DT
- Mehedinti
cutienoua
am gasit ceva si mai fain! ma tenteaza si pe mine desi am un alpine single din cu amplificatorul compact alpine.
Stream Music Through Your System Directly from Your Amplifier
Eliminate the Need of an Expensive Head
HOW BLUETOOTH AMPLIFIERS WORKS
A Bluetooth amplifier is actually a pretty basic piece of equipment. It functions and installs just like any other amplifier would (they can be connected to a source unit, but it isn’t required), it just has an integrated Bluetooth module installed in it allowing you to connect virtually any Bluetooth enabled device (smartphones, tablets, etc.) to it wirelessly. Bluetooth amps eliminate the need of a traditional head unit because they allow the amp to double as the receiver
un exemplu Planet Audio PSA4CB
Class-A/B FullRange 4-Ohm Stable 4-Channel Amplifier
RMS Power Rating:
4 ohms: 94 watts x 4 chan.
Total power output: 500 watts
Pulse Width Modulated MOSFET power supply
Inline Multi-Function Remote included
Weather resistant silicon button controller
Soft start turn-on
aptX Support
Bluetooth A2DP wireless audio streaming
3-way protection circuitry (thermal, overload, and speaker short protection)
Frequency Response: 20 - 20000 Hz
RMS Power Rating:
Soft start turn-on
aptX Support
Mihaiepcs
- Mesaje scrise: 17
- Masina: Astra 2007 Z14XEP
- Cont inregistrat: 27 Dec 2015
- CristianTM
- 3,718 mesaje
- din 15 Mar 2006
- Vectra 2005 Z19DTH
- Timisoara
CristianTM
- Mesaje scrise: 3,718
- Masina: Vectra 2005 Z19DTH
Mihaiepcs
- Mesaje scrise: 17
bilzerian
- Mesaje scrise: 24
- Masina: Astra 2005 Z16XEP
- Cont inregistrat: 07 Oct 2015
Imi cer scuze ca postez aici, insa nu am gasit discutii despre harti navigatie decat din 2008. Ma poate ajuta cineva cu hartile pentru un cd de navigatie pentru Astra H? Ma gandesc ca nu e asa de greu sa faci CD-ul. Poate imi oferiti si cum se face in cazul in care exista vreo procedura speciala, gen ISO nu stiu de care. Multumesc si im cer scuze daca nu am nimerit unde trebuie.
ASTRA-lul
- Mesaje scrise: 8
- Masina: Astra 2007 Y13DTH
- Cont inregistrat: 18 Mar 2018
RIvan426
- Cont inregistrat: 13 Mar 2019
- cristian_fanel
- 5 mesaje
- din 01 Mai 2015
- Zafira 2006
cristian_fanel
- Mesaje scrise: 5
- Masina: Zafira 2006
- Cont inregistrat: 01 Mai 2015
MPogar
- Mesaje scrise: 10
- Cont inregistrat: 31 Mai 2019
- rinoantara
- 67 mesaje
- din 19 Jan 2016
- Antara 2015 z22dm1/LNQ
rinoantara
- Mesaje scrise: 67
- Masina: Antara 2015 z22dm1/LNQ
- Cont inregistrat: 19 Jan 2016
cristian_fanel a scris:Buna ziua.
Detin si eu un opel zafira b echipat cu cd70 navi ecran color.
Ma poate ajuta si pe mine cineva cu un link sau imagine iso a cd-ului cu firmwere updata 2007 sau 2008 pt cd 70 navi.
Email: cristian_fanel@ymail.com
Multumesc mult.
Si scuze daca am postat unde nu trebuie
Multumesc mult.
Nu-ti recomand sa faci update cu cd copiat. Update doar cu cd original !
- rinoantara
- 67 mesaje
- din 19 Jan 2016
rinoantara
- Mesaje scrise: 67
- cristian_fanel
- 5 mesaje
- din 01 Mai 2015
- Zafira 2006
cristian_fanel
- Mesaje scrise: 5
- cristian_fanel
- 5 mesaje
- din 01 Mai 2015
- Zafira 2006
cristian_fanel
- Mesaje scrise: 5
MPogar
- Mesaje scrise: 10
- rinoantara
- 67 mesaje
- din 19 Jan 2016
rinoantara
- Mesaje scrise: 67
