  3. Astra K
  • RCopenhagen
  • Mesaje scrise: 8
  • Cont inregistrat: 20 Mar 2018
Salutare colegi ,
Detin un astra k motor 1.6DTE model 2016 si as dori sa schimb placutele frana spate. Problema ar fi ca am frana de mana electrica . Asadar vine si o intrebare, exista vro posibilitate sa aduc pistonul la pozitia initiala fara deblocare din tester ? Stiu de exemplu ca la audi nu se poate fara comanda din tester, dar la astra j am vazut ca exista o modalitate pentru revenirea la pozitia initiala a pistonului.
Multumesc pentru ajutor
  • dradum
  • Mesaje scrise: 9
  • Masina: Astra 2016 B16SHT
  • Cont inregistrat: 03 Nov 2016
Probabil ai gãsit pânã acum, dar poate ajutã pe alții:
Set the parking brake to service mode.
Manual method
Shift the transmission to the neutral or park position.
Ignition ON and engine OFF.
Pass the brake pedal several times until there is no negative
pressure in the brake booster.
Press the parking brake and the parking brake switch until the
orange parking brake lamp starts to flash. With the brake pedal
depressed, release the parking brake switch for approx. 5 seconds
and press again.
Release the brake pedal. The orange parking brake lamp goes out
for a moment, then the rear calipers are retracted.
Reset the parking brake from service mode.
Manual method
Press the parking brake on the brake pedal and the switch until the
orange parking brake lamp goes off and the rear calipers are
extended.
(https://www.astra-k-forum.de/index.php/Thread/3775-Hintere-Bremsbel%C3%A4ge-wechseln-bei-EPB/)
  • RCopenhagen
  • Mesaje scrise: 8
Multumesc colegu , am efectuat aceasta operatiune si intradevar cand intra in service mode pistoanele pe spate sunt eliberat.
  3. Astra K
