- Mircea Ionut
- 19 mesaje
- din 29 Mai 2013
- Astra 2005 Z16XEP
- Braila
Mircea Ionut
- Mesaje scrise: 19
- Masina: Astra 2005 Z16XEP
- Cont inregistrat: 29 Mai 2013
Masina pornea la rece doar cu mufa egr scoasa...dupa ce se incalzea puteam conecta egr si mergea bine....
Am luat egr nou... am schimbat bujii, nici un rezultat...mni s a spus ca ar fi din Ecu..am pus ECU la sh de la Buc, motorul fiind cald la montaj a mers perfect...a doua zi dimineata a facut la fel..apre pe bord cele doua F uri ...si am inteles ca motorul nu comunica cu calculatorul...
Am pus testerul si mi da urmatoarele erori...
U2111
P0201
P0202
P0203
P0204
P0115-71
P0460-71
P0500-71
P0654-71
P0550-71
Sunt disperat! Masina e din 2006, in garantie a fost inlocuit cym ...are 10000 km, la 60000 i am schimbat bobina...Sunt sfatuit sa schimb din nou bobina si clapeta sau senzorul de la clapeta... V as ruga sa mi dati un sfta! Va multumesc!
- Mircea Ionut
- 19 mesaje
- din 29 Mai 2013
- Astra 2005 Z16XEP
- Braila
Mircea Ionut
- Mesaje scrise: 19
- Mircea Ionut
- 19 mesaje
- din 29 Mai 2013
- Astra 2005 Z16XEP
- Braila
Mircea Ionut
- Mesaje scrise: 19
- Mircea Ionut
- 19 mesaje
- din 29 Mai 2013
- Astra 2005 Z16XEP
- Braila
Mircea Ionut
- Mesaje scrise: 19
Subject: diagnoza astra h
DIAGNOSTIC REPORT:
OP-COM 100219a
hkj
**********************ECU ID STARTS**********************
Source Address: CIM
Source Address: 0x00000245
Identifier: 0x010A
VIN: W0L0AHL4868077069
System name: VALEO A3300 CIM
Hardware number:93184341
Part Number:93184341
Software version number: M:10.57 S:01.00A
System description: VALEO0400
Hardware key number: H000007291
Programming Date: FFFFFFFF
Alpha code: ÿÿÿ
Manufacturing date: 20061009
Code Index and version: ÿÿÿ ÿÿ
Number of stored fault codes: 3
U2100 - No Communication with CAN-Bus (High Speed)
(00) - Not present
U2105 - CAN-Bus No Communication with ECM (Engine Control Module)
(00) - Not present
U2111 - CAN-Bus No Communication with EPS (Electrical Power Steering)
(00) - Present
**********************ECU ID ENDS**********************
Source Address: ECM
Source Address: 0x000007E0
Identifier: 0x0103
System name: Z16XEP
Hardware number:12222040
Part Number:12230740
Software version number: 01AD3717
System description: DELCO0100
Type approval number: D04004
Hardware key number: H000008745
Programming Date: 20080703
Alpha code: TB
Software version: P1003A15
ECU variant coding: 0x000014C5
Number of stored fault codes: 12
P0201 - Cylinder 1 Injector Malfunction
(00) - Present
P0202 - Cylinder 2 Injector Malfunction
(00) - Present
P0203 - Cylinder 3 Injector Malfunction
(00) - Present
P0204 - Cylinder 4 Injector Malfunction
(00) - Present
P0230 - Fuel Pump Primary Circuit Low
(02) - Not present
P0650 - IPC Message range/Performance (Instrument)
(70) - Not present
P1550 - Electronic Throttle Control Reduced Power
(5A) - Not present
P1600 - Replace Electronic Control Unit (ECU)
(3A) - Not present
U2103 - CAN-Bus Node no Communication
(00) - Not present
U2104 - CAN-Bus Reset Counter Overrun
(00) - Not present
U2108 - Invalid Data from ABS (Anti Lock Brake System)
(70) - Not present
U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
(70) - Not present
Source Address: ABS/TC/ESP
Source Address: 0x00000243
Identifier: 0x0403
System name: ABS MK70
Hardware number:17009000
Part Number:13157576
Software version number: D2_BAO00047
System description: TEVES0300
Programming Date: 00000000
Alpha code:
Manufacturing date: 20051209
ECU variant coding: 0x00001143
Number of stored fault codes: 2
(00) - Not present
(00) - Not present
Source Address: ECC
Source Address: 0x00000248
Identifier: 0x0201
System name: ECC A3300
Hardware number:24452694
Part Number:13122963
Software version number: 0AL00/29C68
System description: PREH 0000
Alpha code: 000
Manufacturing date: 20051212
Code Index and version: 005 01
No fault codes stored.
Source Address: EHU
Source Address: 0x00000241
Identifier: 0x0207
System name: CD 30 MP3
Hardware number:13187939
Part Number:13188461
Software version number: 06.00/-----
System description: BOSCH0400
Alpha code: LC
Manufacturing date: 20051215
Code Index and version: 002 05
Audio Index and version: 022 04
Source Address: DIS
Source Address: 0x00000246
Identifier: 0x1201
System name: CID/GID Delta
Hardware number:13178570
Part Number:13178570
Software version number: GD59-/00050
System description: SIEM 0400
Alpha code: SE
Code Index and version: 007 01
U2139 - Invalid Data from CIM (Steering Column Module)
(71) - Not present
iata si diagnoza actuala!
Dany7776- Suspendat
- 342 mesaje
- din 02 Nov 2011
Dany7776- Mesaje scrise: 342
- Cont inregistrat: 02 Nov 2011
Nu strica sa-i ceri un sfat.
Cerei macar o indrumare, altul nu stiu sa te indrume corect.
Sau intreaba-l pe "dancuciureanu" si el le are cu ECU .etc
Bafta!
P.S: Nu mai fi disperat solutii sunt.
- ALpinE1991
- 40 mesaje
- din 04 Jun 2013
- Astra 2005 z17dth
- Dambovita
ALpinE1991
- Mesaje scrise: 40
- Masina: Astra 2005 z17dth
- Cont inregistrat: 04 Jun 2013
- CristianTM
- 3,692 mesaje
- din 15 Mar 2006
- Insignia A Fastback 2010 A20DTH
- Timisoara
CristianTM
- Mesaje scrise: 3,692
- Masina: Insignia A Fastback 2010 A20DTH
CristianTM.
- Georgius
- 380 mesaje
- din 12 Sep 2015
- Astra 2005 Z16XEP
Georgius
- Mesaje scrise: 380
- Cont inregistrat: 12 Sep 2015
Terenaam
- Mesaje scrise: 37
- Masina: Vectra 2002 Z18XE
- Cont inregistrat: 11 Aug 2018
