  2. Opel Zafira
  3. Zafira A
  • GFOUDIS
  • Masina: Zafira 2002 Z16XE
  • Cont inregistrat: 15 Jul 2019
Bunã ziua, sunt nou în club și aș dori sã întreb: În Zafira I, am instalat cu succes pilotul automat. Cu toate acestea, lampa de ceas de pe ceas nu existã. Ce trebuie sa fac pentru a lucra ? Multumesc!
MODEL: Zafira 2002
MOTOR: Z16XE
  • Mr.Opel
  • Mesaje scrise: 2,285
  • Masina: Astra 2001 Y17DT
Hi and welcome,
Fell free to use english if you don't speak romanian.
If you're using google translate, it's not doing a great job.
This part is difficult to understand. Try in english or rephrase.
  • GFOUDIS
Could you please tell me how to activate led light for cruise control? I put an smd and a 680 Ohm resistor on the tacho but it is not lighting.Do i have to do something else? The cruise control works fine,but i would like to have the led indication. Thanks in advance!
  • mikyboy
  • Mesaje scrise: 5,735
you need to wire that LED in the bord from ECU...
https://www.clubopel.com/viewtopic.php?t=22073 see here maybe it will help you Smile
  • GFOUDIS
I am a little confused readi g all the thread. For Z16XE engine is pin 23 of ECU to pin 14 of instrument panel.?
  • GFOUDIS
Sunt puțin confuzã în citirea întregului fir. Pentru motorul Z16XE se fixeazã pinul 23 al ECU la pinul 14 al panoului de bord?
  2. Opel Zafira
  3. Zafira A
