- bazate
- 479 mesaje
- din 26 Sep 2016
- Grandland X 2018 B12xht
bazate
- Mesaje scrise: 479
- Masina: Grandland X 2018 B12xht
- Cont inregistrat: 26 Sep 2016
Stie cineva procedura de reset idle learn?
Am gasit ceva dar de regula se cere scanner care sa dea comanda de resetare.
• The engine coolant temperature must be below 30°C
• The air conditioning must be set to
1. Switch the ignition off then on.
2. Scan tool sends the command to reset.
3. Switch the ignition off then on again.
4. Wait for 10 seconds.
5. Start the engine.
6. Run the engine at idle until the fans cut-in (Air conditioning must be off).
7. Switch off the ignition to store the new values.
8. Wait for 12 minutes while the CM powers down.
9. Switch on the ignition.
10. Wait for 15 seconds
11. Start the engine.
12. Before returning the vehicle to the customer a test drive should be undertaken
during which time an injection cut-off should be triggered. This is achieved by
driving the vehicle in 3rd, 4th or 5th gear and sharply releasing the accelerator
Model: Grandland X
An fabricatie: 2018
Cod motor: B12xht
Model: Grandland X
An fabricatie: 2018
Cod motor: B12xht
- dcrst75
- 132 mesaje
- din 30 Mai 2018
- Grandland X 2018
- Mehedinti
dcrst75
- Mesaje scrise: 132
- Cont inregistrat: 30 Mai 2018
- bazate
- 479 mesaje
- din 26 Sep 2016
bazate
- vladspaniolul
- 70 mesaje
- din 07 Aug 2007
- Grandland X 2018 B16DTH
- Vaslui
vladspaniolul
- Mesaje scrise: 70
- Masina: Grandland X 2018 B16DTH
- Cont inregistrat: 07 Aug 2007
- bazate
- 479 mesaje
- din 26 Sep 2016
bazate
- vladspaniolul
- 70 mesaje
- din 07 Aug 2007
- Vaslui
vladspaniolul
- Mesaje scrise: 70
