- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
- Mesaje scrise: 337
- Masina: Astra 2005 Z16XEP
- Cont inregistrat: 17 Feb 2013
P1483
Fan Control 3 Circuit High Voltage
Final stage diagnosis in control unit
(Short circuit to voltage)
P2108 – Throttle actuator control (TAC) module – performance problem
P0500
Vehicle Speed Signal Range/Performance
The control unit recognises the malfunction of the circuit via an internal evaluation logic.
P1604
REPLACE
ECU
• The control unit cannot store the learned values and adjustments in the EEPROM
• The fault is immediately recognised with ignition ON.
Effect:
• The system telltale is switched on.
• The EEPROM configuration number read by the control unit is not correct
Effect:
• The engine does not start.
P1125
Throttle Actuator Feedback Signal Range/Performance
Signal lead indicates an implausible value.
Above condition must be fulfilled for at least 0.3 - 4 s .
P1278 - Accelerator Pedal Position Sensor 1 Circuit High Voltage
Le poti traduce pe fiecare cu google translate dar in principal e defect ECU si trebuie inlocuit...restul erorilor (pedala de acceleratie,senzor de viteza...) sunt adiacente si decurg din eroarea principala P1604 - Inlocuire ECU.
P0500
P1604
REPLACE
ECU
Effect:
Effect:
P1125
- IRoberto102
- 6 mesaje
- din 19 Oct 2019
IRoberto102
- Mesaje scrise: 6
- Cont inregistrat: 19 Oct 2019
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
Nu trebuie ECU nou ...e bun si unul din dezmembrari dar sa fie de pe o masina la fel (astra h 1.7 101 cp) si cineva priceput ca sa-l inlocuiasca. cauta aici https://www.clubopel.com/rez...+ECU&sa=Cauta
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
- IRoberto102
- 6 mesaje
- din 19 Oct 2019
IRoberto102
- Mesaje scrise: 6
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
- IRoberto102
- 6 mesaje
- din 19 Oct 2019
IRoberto102
- Mesaje scrise: 6
- IRoberto102
- 6 mesaje
- din 19 Oct 2019
IRoberto102
- Mesaje scrise: 6
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
lobea
- Mesaje scrise: 21
- Masina: Astra 2006 Z16XEP
- Cont inregistrat: 06 Jan 2017
lobea
- Mesaje scrise: 21
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
Banuiesc ca e ECN 013055 Nu? codul ECN e din 6 cifre primele 4 sunt codul P0130 sonda lambda 1 defecta Este pozitionata pe evacuare inainte de catalizator si se vede cum deschizi capota
http://www.youtube.com/watch?v=9nA3Us8hk24
lobea
- Mesaje scrise: 21
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,916
- Masina: Corsa 2001 Z12XE
lobea
- Mesaje scrise: 21
lobea
- Mesaje scrise: 21
- thirteen
- 337 mesaje
- din 17 Feb 2013
- Astra 2005 Z16XEP
- Alba
thirteen
lobea
- Mesaje scrise: 21
Da mi a pare codul,dar mi a spus cineva sa dau cu spray de contact la mufa de la sonda lambda ca se mai oxideaza pinii si de acolo ar putea veni acest "dat in nas"!Am scos si mufa in timpul functionarii motorului!Testul l am facut cu pedalele(acceleratie,frana).Inainte de a scoate mufa nu imi dadea nici un cod de eroare!Multumesc!
