  • bertone
  • Mesaje scrise: 2,294
Revin cu o problema care dupa search pe forum , vad ca nu s-a acoperit .
Smecherii dupa ce mi-au luat banii la revizie n-au facut un lucru elementar si anume sa reseteze inspectia .
Problema este ca nu merge clasic , ca la celelalte modele de Opel . Am tinut si un minut mana pe reset , am pornit , am oprit , ce naiba n-am facut !
Apare ca se reseteaza inspectia ( linutele alea in loc de km ) dar .. surpirza la urmatorul contact pus nu se reseteaza nimic . Apar iar km pana la revizie .
Ceva sugestii care sa excluda 60 de lei la tester ? Very Happy
  • Mikki
  • Mesaje scrise: 1,418
  • Masina: Astra 2002 1.6
Trebuie sa tii apasata si pedala de frana inainte de a apasa reset
  • lupu_sandu
  • Mesaje scrise: 622
  • Cont inregistrat: 25 Aug 2007
Scump dom' Bertone, scump. 60 lei?
Si Op-Com spune sa tii frana apasata cand faci un SRI reset. Smile
De acolo am vazut poanta.
  • claudiu__
  • Mesaje scrise: 473
  • Cont inregistrat: 27 Apr 2008
Resetting the Service Interval Display, Astra-H and Vectra-C/Signum with Z 19 DT and Z 19 DTH
1
"Ignition OFF".
2
Press reset button (mileage trip) briefly, the display in the instrument panel shows the odometer and mileage trip counter.
3
Press reset button (mileage trip button) and hold, after approx. 3 seconds the service interval display will appear (e.g. "InSP 15,000" or "InSP 0").
4
Keep reset button pressed, in addition, depress brake, hold both.
5
"Ignition ON". Keep the reset button pressed and the brake pedal depressed, "InSP - - - " will flash in the display. Continue to hold both until the service interval display changes.
6
After approx. 10 seconds the maximum distance will be displayed (InSP" 35,000 km petrol engine or "InSP" 50,000 diesel). The service interval has been reset.
  • bertone
Multam de raspunsuri .
Nu-i scump 60 de lei , ci indecent avand in vedere ca ti-o faci singur acasa Very Happy
  • popescu iulian
  • Mesaje scrise: 1,400
  • Masina: Antara 2012 A22DMH
Nu-i scump, ci oribil de scump 60 ron pentru 30 sec . => 7200 ron ora de manopera.
  • manai_nfs
  • Mesaje scrise: 15
  • Masina: Astra 2000 y20dti
  • Cont inregistrat: 29 Sep 2008
puteti sa-mi spuneti si mie cum resetez InSP la y20 dti?
  • edyionut
  • Mesaje scrise: 318
  • Masina: Astra 2005 Z17DTL
  • Cont inregistrat: 26 Oct 2007
bagi cheia in contact, apesi butonul din bord ( cel de linga km) concomitent cu punerea contactului si stai asa 2-3 secunde.Apoi tai contactul si gata
  • manai_nfs
  • Mesaje scrise: 15
merci frumos.am mers imediat.
  • Fialdo
  • Mesaje scrise: 130
  • Masina: Astra 2003 Y20DTH
  • Cont inregistrat: 15 Jul 2007
manai_nfs a scris:puteti sa-mi spuneti si mie cum resetez InSP la y20 dti?
Mod de resetare contor "InSP":
1. Se intrerupe contactul motorului, cheia va fi pe pozitia "O"
2. Se apasa butonul de resetare si se tine apasat (este butonul de la reset - aducere la zero - km realizati zilnic)
3. Se stabileste contactul motor, tinandu-se totodata cateva secunde si butonul reset km apasat
4. Dupa stabilirea contactului motor "InSP" va clipi la un moment dat cateva secunde, apoi va aparea afisat "----" pana cand se va elibera butonul
5 In final va aparea kilometrajul zilnic
  • bertone
cred ca se poate inchide topicul
  • vali_fcs
  • Mesaje scrise: 11
  • Masina: Astra 2006
  • Cont inregistrat: 30 Oct 2009
Salut
Am opel astra H 2006 1.7 74kw
Am vrut sa resetez INSP dar nu am mai pus contactul si mi-a aparul 1.7 sus si jos 000105 inloc sa se reseteze INSP
Apoi am pus contactul si am reusit.
Dar intrebarea mea este ce am facut si ce mi-a aparut ca sunt foarte curios(am sa mor repede stiu).
Multumesc anticipat.
  • Ionut08
  • Mesaje scrise: 32
  • Masina: Astra 2006 Z17DHT
  • Cont inregistrat: 18 Mar 2012
Salut , am astra h si la mine la 2000 km se reseteaza cum fac sa se reseteze la 10000 km .
  • Ionut08
  • Mesaje scrise: 32
  • fumezenorm
  • Mesaje scrise: 27
  • Cont inregistrat: 15 Feb 2012
Am si eu o problema la inceput imi aparea insp dupa care imi apareau km cat scoteam cheia din contact iar aparea insp. Am urmat passi problema sa rezolvat temportar vreo 5000 de km
noua problema cand bag cheia apare insp 35000 si nu mai imi arata km din bord doar INSP 35000 si sta aprins tot drumu nu mai pot sa vad km nici cum la masina doar cand descui masina
vreo solutie va rog ?
  • maxx_bgd
  • Mesaje scrise: 46
  • Masina: Astra 2006 z17dtl
  • Cont inregistrat: 04 Sep 2014
Salut. Imi apareau in bord la punerea contactului mesajele ”InSP” si ”InSp 3”. AM resetat utilizand metoda aceea cu apasarea pe butonul de resetare al km si punerea contactului. Nu imi mai apare mesajul ”InSP” insa imi apare ”InSP 3”. Din cate am inteles ”InSP 3” apare cand bateria din telecomanda (cheie) trebuie schimbata. Acel mesaj nu se poate sterge, sau la schimbarea bateriei telecomenzii dispare automat?
  • veve73
  • Mesaje scrise: 23
  • Masina: Zafira 2014
  • Cont inregistrat: 18 Aug 2013
Referitor la resetarea InSP.Dupa ce am am facut resetarea , la 2-3000 km a aparaut iarasi mesajul de InSP cu km 0.L-am resetat din nou si la fel dupa cateva mii de km a reparut mensaul de InSP. Ce poate sa fie? Am o Zafira B 17DTH
  • zerillos
  • Mesaje scrise: 69
  • Masina: Astra 2007
  • Cont inregistrat: 01 Dec 2015
Eu am masina de 2 saptamani, deci nu-i stiu toate chichitele. Am luat masina si cand pun contactul imi apare becul cu masina si cheia de service + InSP. Bine, apar si celelalte uzuale de care nu discut acum. Ce am de facut? Sa ma duc la revizie, apoi sa resetez InSP? Se va sterge automat si becul din bord cu masina si cheia de service? Sau asta indica o alta problema?
Mentionez ca dupa ce pornesc motorul ele dispar, dar cand pun contactul inainte de pornire apar.
  • viorel_bce
  • Mesaje scrise: 458
  • Masina: Astra 2008 Z17DTJ
  • Cont inregistrat: 19 Sep 2010
Insp-ul se poate reseta cum s-a discutat aici,pentru cealalta problema ai ceva eroare stocata si trebuie facut un text pseudoagrafa sau pus o interfata de diagnoza si vazut ce eroare ai.
https://www.clubopel.com/viewtopic.php?t=24014
  • LNISCOV
  • Cont inregistrat: 30 Apr 2020
CUM RESETEZ iNSP LA ASTRA H 1,7 CTDI 2005 ISUZU Z17DTL ?
Ce parere aveti de motorul ISUZU ?
VA MULTUMESC ANTICIPAT !
