- LDivora
- 3,067 mesaje
- din 30 Mai 2005
- Astra 2003 Y20DTH/PSG16
LDivora
- Mesaje scrise: 3,067
ELECTRICAL WIRING ABBREVIATION (ABREVIERI IN SCHEMELE ELECTRICE)
(abrevierile provin din limba germana si sunt in ordine alfabetica)
Conductoare de alimentare:
30 - +12V direct din acumulator;
15 - +12V prin cheie contact poz. II si III;
15A - +12V prin cheie contact numai poz. II;
50 - +12V prin cheie contact numai poz. III;
W - +12V prin cheie contact poz. I, II si III;
┴1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16 – Puncte de masa (-);
AB – Airbags (Airbag-uri);
ABS – Anti-lock brake system (ABS – sistem antiblocare frane);
AC – Air conditionning (Aer conditionat);
ASP – Outside mirrors (Oglinzi exterioare reglabile si incalzite);
AT – Automatic transmission (Transmisie automata);
ATS – Switch automatic transmission (Switch transmisie automata);
AZV – Socket trailer (Priza remorca);
BLW – Turn signal lamps, hazard warning (Lampi semnalizare, avarie);
CC – Check controll (Modul de verificare integritate becuri);
CD – CD changer (Magazie CD);
CID - Color info display (Afisor color informatii multiple);
CRC – Cruise controll (Tempomat, pilot automat);
CRP – Carphone (Telefon);
DIAG – Diagnostic link (Cupla diagnoza);
DWA – Anti theft warning unit (Modul alarma);
ECC – Electronic climate controll (Climatronic);
EHPS – Electro-hydraulic power steering (Servo-directie electro-hidraulica);
EIS – Electrical miror inside (Oglinda electrica interior);
EMP – Radio (Radio);
ESP – Electronic stability program (Control electronic al stabilitatii);
EZH – Electronic auxiliary heater (Incalzire auxiliara controlata electronic);
FH – Window lifter (Ridicare geamuri electrice);
FIL – Filter heating (Incalzire filtru motorina);
Fx.x – Fuse (Siguranta);
GBL – Blower passenger compartment (Aeroterma);
GID - Graphic info display (Afisor grafic informatii multiple);
GPS – Global positioning system (GPS);
HORN – Horn signal (Claxon);
HS – Back window-heated (Incalzire luneta);
IMO – Immobiliser (Imobilizator);
INS – Instrument (Ceasuri bord);
IPL – Lamps passenger compartment, front (Lampi pasager fata);
IRL – Lamps passenger compartment, rear (Lampi pasager spate);
KAB – Curtain airbags (Airbag-uri cortina);
KSP – Fuel pump (Pompa carburant);
KZL – Lamp licence plate (Lampi numar inmatriculare);
LHD – Left hand (Volan stanga);
LWP – Headlamp leveling – not xenon (Reglaj electric faruri– exceptand xenon);
LWR – Headlamp leveling – xenon (Reglaj electric faruri - xenon);
MID - Multiple info display (Afisor informatii multiple);
MK – Engine cooling without AC (Racire motor fara instalatie de AC);
MKK - Engine cooling module with AC (Modul racire motor cu instalatie de AC);
MKM - Engine cooling module diesel with AC (Modul racire motor diesel cu instalatie de AC);
MUT – Multitimer (Modul multitemporizari);
NAV – Navigation (Navigatie);
NSW – Fog lamp (Lampi ceata);
PBSL – Park brake shift lock (Sistem blocare frane parcare, cutie automata);
PP – Park pilot (Senzori parcare);
RFB – Remote controll, radio (Comenzi volan radio);
RFS – Back up lamps (Lampi mers inapoi);
RHD – Right hand (Volan dreapta);
SBR – Switch stop lamp (Switch stop pe frana);
SD – Sun roof (Trapa);
SH – Seat heating (Incalzire scaune);
SHL – Sunshade lamps (Lampi parasolare);
SKL – Switch cluch (Switch ambreiaj);
SRA – Vasher-headlamps (Instalatie spalare faruri);
ST – Soft top (Decapotare);
TC – Traction controll (Control electronic al tractiunii);
TEL – Connector phone (Conector telefon);
TFL – Daytime running light- not xenon (Lumini de drum de zi – exceptand xenon);
TID – Triple info display (Afisor cu 3 informatii);
TKS – Door contact switch (Contacte inchidere usi);
TM – Telematic (Sistem telematic, microfon);
TVC – Phone/voice controll (Unitate de control voce);
ZIG – Cigarette lighter (Bricheta);
ZH – Auxiliary heating (Incalzire auxiliara, sirocou);
ZV – Central locking (Inchidere centralizata);
WA – Wiper system (Sistem stergatoare);
WEG – Sensor distance (Senzor distanta);
WS – Warning buzzer (Atentionare sonora);
Incercati sa dati o sugestie pentru SHL, eu nu am gasit-o.
Ultima modificare făcută de LDivora la Mie 03 Dec, 2008 9:23 am, modificat de 2 ori în total
- petrecila
- 1,093 mesaje
- din 25 Apr 2007
- Bacau
petrecila
- Mesaje scrise: 1,093
- Cont inregistrat: 25 Apr 2007
- LDivora
- 3,067 mesaje
- din 30 Mai 2005
LDivora
- Mikki
- 1,418 mesaje
- din 06 Sep 2004
- Astra 2002 1.6
Mikki
- Mesaje scrise: 1,418
- Masina: Astra 2002 1.6
- Cont inregistrat: 06 Sep 2004
- gabonne
- 1,293 mesaje
- din 11 Sep 2006
- Vectra 1993 1.7TD
- braila
gabonne
- Mesaje scrise: 1,293
- Masina: Vectra 1993 1.7TD
- LDivora
- 3,067 mesaje
- din 30 Mai 2005
LDivora
- pif
- 1,301 mesaje
- din 04 Nov 2004
- Vectra 2001 z18xe
- Gaesti/Dambovita
pif
- Mesaje scrise: 1,301
- Masina: Vectra 2001 z18xe
- Cont inregistrat: 04 Nov 2004
- LDivora
- 3,067 mesaje
- din 30 Mai 2005
LDivora
- gabonne
- 1,293 mesaje
- din 11 Sep 2006
- Vectra 1993 1.7TD
- braila
gabonne
- chuckye2005
- 83 mesaje
- din 07 Nov 2008
- Omega 1996 X30XE
- Valcea
chuckye2005
- Mesaje scrise: 83
- Masina: Omega 1996 X30XE
- Cont inregistrat: 07 Nov 2008
