  2. Opel Corsa
  3. Corsa B/Combo B
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
  • Cont inregistrat: 02 Aug 2016
Salutare.
Pentru ca tata nu prea stie sa umble pe forum-uri, sa faca topic-uri si asa mai departe am decis sa postez in locul lui.
Aseara a plecat la serviciu, cand a pornit masina acul vitezometrului s-a dus la 200 si a ramas asa. Apoi, dimineata si-a revenit, ca dupa un timp sa se duca iar la 200. Stiti de la ce ar putea fi? Nu se duce deodata la 200 ci acelereaza normal si chiar daca ia piciorul de pe acceleratie acul urca pana la 200 si ramane acolo.
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
up
  • T.ion
  • Mesaje scrise: 3,454
  • Masina: Zafira 2001 Z16XE
Banuiesc ca ai unul dintre aceste motoare X10XE, X12XE.
Vezi ce are pe el, ulei din cutie etc... sau este defect, fire mufe etc...
Cum se verifica nu am idee.
VSS - Vehicle Speed Sensor Gearbox Position
ottosump a scris: Location of Gearbox speed sensor & removal advice on X10XE & X12XE engine
Location of gearbox speed sensor highlighted
As a precaution, always disconnect the battery before removing any electrical equipment.Remove the wiring connector, thumb release clip is on the back of the connector (if stiff this can be removed after extracting the sensor) The sensor is secured by one 10mm bolt highlighted in green, I found it easier to get at using a couple of socket extensions with a flexi connector.
Gearbox speed sensor removed. This one was quite stiff to remove, had to do a fair bit of wriggling before it finally gave up.
Sensor in all its glory, note the green seal, make sure that this is not damaged if re-fitting. (This one is clearly damaged)
Apologies if anyone else has already submitted a similar thread, but I couldn't find one with pictures.
Happy motoring to all ! Otto
Vezi ce model ai pe masina ca vad ca sunt doua.
9114603 | 1236304 - TRANSMITTER,DISTANCE FREQUENCY,15 IMPULSES
90532632 | 1236281 - TRANSMITTER,DISTANCE FREQUENCY,15 IMPULSES
http://www.ecat24.com/opel/...5/570/2175/20989/
Vezi ce cumperi sau cauta unul exact la fel la dezm...
Eventual ii faci o curatare.
Sau poate sa fie de la altceva... eu unul il banuiesc pe el.
il dai jos si vezi cum se prezinta el si zona unde vine el, mufa firele il cureti si ii faci o proba.
Uleiul din cutie ai completat sa fie la nivel.
Corsa B - scheme/probleme electrice - cauze/solutii
www.clubopel.com/viewtopic.php?p=876670
Diagram 8 |
64 speed sensor. "See Diagram 14 Instrument Cluster"
  • T.ion
Diagram 8 |Cautati 64 speed sensor.
Diagram 14 | cautati litera m) si mergeti pe fir.
Daca nu ai umblat pana acum la cutie iti recomand sa schimbi uleiul din cutie nici masina nu mai este tanara.
GM 1940182 | ai nevoie de 1.6 L
https://www.clubopel.com/vie...p?p=145943#145943 ...
https://www.clubopel.com/vie...p=1827834#1827834 ....
https://www.clubopel.com/rez...sa+b&sa=Cauta
Si pana la urma ce motor are masina?
Vezi ce mai spun colegi.
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
Tipul motorului: X17D
  • T.ion
Cauta-l in zona aceea.
Daca il gasesti sa pui o poza cu el unde se afla pe masina.
Poate vor mai fi colegi care il cauta.
Stii cum va ce tip cutie de viteze are?
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
La mine este asemanator ca in pozele tale, dar am facut cateva detalii pe poza: http://imgur.com/a/Yia5K
Se pare ca senzorul este asta: http://imgur.com/a/b7Z8V O sa il scot de acolo si o sa il curat, sa vedem poate merge, daca nu trebuie schimbat.
Iar cu schimbatul uleiului este o problema, nu are un loc pe unde se scurge(trebuie sa ma uit si sub masina sa vad) asta inseamna ca trebuie scos capacul transmisiei de dedesupt cu grija. Am mai cautat pe youtube si am gasit un tutorial: http://www.youtube.com/watch?v=hqF6JLSGkcE Deci probabil o sa scot acel capac de la transmisie ca sa-l inlocuiesc. Bineinteles ca nu este aceeasi masina, dar tot pe principiul asta trebuie sa inlocuiesc uleiul.
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
Habar n-am de cutie.
Edit: Va multumesc foarte mult pentru ajutor, daca rezolv problema o sa revin cu un edit sa va spun care a fost problema.
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
Am revenit cu ce am mai facut.
Se pare ca astazi am decis sa scot acel senzor sa vad care este treaba. L-am scos frumos, am scos si chestia aceea care intra in cutie si are o rotita, le-am curatat bine si le-am pus inapoi. Rezultatul? Pai se pare ca nu s-a rezolvat nimic. Am scos iar rotita aia cand era masina pornita si am dat de ea,a ajuns la 200 si acolo a ramas. Le-am pus la loc am mers putin cu masina si nimic. A ramas la 200 blocat. Câteodatã isi da drumul, in sensul ca, pornesc masina si coboara acul indicator la 0 si functioneaza ca si cum nu s-ar fi intamplat nimic. Credeti ca este de vina ceasul din bord?
  • T.ion
Daca mergi cu el fara mufa pusa, ce se intampla?
Verifica mai atent pini din mufa.. cat si din pini de la senzor... (oxidari, o curatare la pini nu ii strica)
Vezi ce spun si colegi.
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
Pai a ramas la 200 si cand am mers fara mufa nu s-a intamplat nimic. Pinii din senzor i-am curatat..
  • Stefan300
  • Mesaje scrise: 8
  • Masina: Corsa
Se pare ca problema este de la vitezometru si trebuie schimbat. Imi puteti de ce trebuie sa tin cont atunci cand cumpar unul?(bineinteles inafara de mufa)
http://imgur.com/a/hmddF uitati asa arata pe spate.
  2. Opel Corsa
  3. Corsa B/Combo B
