- petro
- 103 mesaje
- din 06 Feb 2008
- Vectra 2004 y20dth
petro
- Mesaje scrise: 103
- Masina: Vectra 2004 y20dth
- Cont inregistrat: 06 Feb 2008
In mers apare martoul masinuta cu cheita si nu se mai accelereaza. Am verificat furtunele de vaccum, am facut diagnoza cu OP-COM si am doua erori....
-P0638-throttle control circuit negative deviation(5A)-not present
-P0630-electronic throttle sensor circuit high input(07)-not present.
Incerc o curatare de EGR cum am citit intr-un tutorial sau trebuie schimbat din start EGR-ul si electrovalva?
- adware_man
- 1,724 mesaje
- din 01 Oct 2008
- Astra 2002 Y20DTH
adware_man
- Mesaje scrise: 1,724
- Masina: Astra 2002 Y20DTH
- Cont inregistrat: 01 Oct 2008
suspended-9452- Suspendat
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
suspended-9452- Mesaje scrise: 2,412
- Masina: Astra 2016 B14XER
stiu despre ce e vorba.
am intalnit asta tot la o vectra c.
da-mi un telefon cand esti la masina si-ti explic.
nu ai nici o treaba cu egr.
este vb. de un senzor.
[editat]
- adware_man
- 1,724 mesaje
- din 01 Oct 2008
- Astra 2002 Y20DTH
adware_man
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
- adware_man
- 1,724 mesaje
- din 01 Oct 2008
- Astra 2002 Y20DTH
adware_man
c0sty
- Mesaje scrise: 73
- Cont inregistrat: 02 Jul 2012
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
- sevenx
- 118 mesaje
- din 17 Dec 2009
- Vectra 2004 Y20DTH
sevenx
- Mesaje scrise: 118
- Masina: Vectra 2004 Y20DTH
- Cont inregistrat: 17 Dec 2009
- iulian1971
- 7,040 mesaje
- din 21 Dec 2006
- Ilfov
iulian1971
- Mesaje scrise: 7,040
P0638 Throttle Control Solenoid Valve Low Voltage B-019
P0638 Throttle Control Solenoid Valve Circuit open B-019
P0638 Throttle Control Solenoid Valve Powerstage High Temperature C-017
P0638 Electronic Throttle Sensor Circuit High Input C-018
P0638 Electronic Throttle Sensor Circuit Low Input C-018
P0638 Throttle Control Circuit Positive Deviation B-014
P0638 Throttle Control Circuit Negative Deviation B-014
In afara de senzorul de pozitie clapeta, verificati furtunasele de vacum ale electrovalvelor si terminatiile de cauciuc din capete. Posibil sa piarda vacum si tot circuitul devine inoperabil.
- sevenx
- 118 mesaje
- din 17 Dec 2009
sevenx
P0638 - Electronic Throttle Sensor Circuit High Input (07)
si a inceput sa apara dupa ce mi-au fost curatate EGR-ul si clapeta de acceleratie. Acolo era un jeg de nedescris incat 2 clapte nu mai oscilau deloc iar 2 doar partial.
De atunci tot am problema....idei au mi aparut insa fara o testare riguroasa (sa schimb senzorul cu tot cu corp, sa schimb electrovalvele, sa desfac turbina ca sgur este de la ea ca are joc in ax)...insa nu m-as baga sa dau bani pana nu sunt sigur care este cauza.
- sevenx
- 118 mesaje
- din 17 Dec 2009
sevenx
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
- sevenx
- 118 mesaje
- din 17 Dec 2009
sevenx
catalinpav66- Suspendat
- 759 mesaje
- din 29 Oct 2008
- Vectra 2006 z30dt
catalinpav66- Mesaje scrise: 759
- Masina: Vectra 2006 z30dt
- Cont inregistrat: 29 Oct 2008
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
uite aici :
https://www.clubopel.com/vie...80&highlight=
- sevenx
- 118 mesaje
- din 17 Dec 2009
sevenx
- sorin muntean
- 4 mesaje
- din 09 Mai 2009
- Vectra 2004 Y2,0DTI
- Timis
sorin muntean
- Mesaje scrise: 4
- Masina: Vectra 2004 Y2,0DTI
- Cont inregistrat: 09 Mai 2009
uite aici :
eu am facut asta demult si tot mai apare acest cod , eu am anulat acest senzor cand "galopa" motorul . Daca tot mai apare ce crezi ca mai poate fi ?
- 2,412 mesaje
- din 04 Sep 2007
- Astra 2016 B14XER
- sorin muntean
- 4 mesaje
- din 09 Mai 2009
- Timis
sorin muntean
- Mesaje scrise: 4
