- popescu iulian
- 1,400 mesaje
- din 19 Jun 2006
- Antara 2012 A22DMH
- Timisoara
popescu iulian
- Mesaje scrise: 1,400
- Masina: Antara 2012 A22DMH
- Cont inregistrat: 19 Jun 2006
Fratilor daca a curatat cineva valva EGR la motorul de y17dt sa ne spuna si noua cum a facut, sa ne puna si niste poze ca m-as baga la asa ceva dar chiar nu stiu unde e valva aia. Am vazut ca unii cu y20dtl au curatat si admisia, hai sa n e impartasiti si noua astora care nu prea umblam prin motor cum se face sa nu ne stricam masinile.
- denilson2160
- 155 mesaje
- din 07 Jan 2005
- Astra 2001 Y 20 DTH
denilson2160
- Mesaje scrise: 155
- Masina: Astra 2001 Y 20 DTH
- Cont inregistrat: 07 Jan 2005
vedeti aici si nu va speriati ca este opel vectra , principiul este acelasi:
http://www.opel-vectra.com/...net_vanne_egr.php
- maiandrei
- 4,711 mesaje
- din 20 Dec 2004
- Insignia 2018 B20DTH
maiandrei
- Mesaje scrise: 4,711
Exhaust Gas Recirculation Valve, Remove and Install (Y 17 DT)
Remove
Remove exhaust gas recirculation pipe – see operation "Exhaust Gas Recirculation Pipe, Remove and Install (Y 17 DT)".
Remove vacuum hose (1) from exhaust gas recirculation valve.
Remove exhaust gas recirculation valve (2) from two-part intake manifold.
Clean
Clean sealing surfaces and remove gasket residue.
Install
Attach exhaust gas recirculation valve to two-part intake manifold – tightening torque 24.5 Nm / 18 lbf. ft.
Attach vacuum hose to exhaust gas recirculation valve.
Install exhaust gas recirculation pipe – see operation "Exhaust Gas Recirculation Pipe, Remove and Install (Y 17 DT)"
Preluat din TIS
Remove
Clean
Install
Preluat din TIS
- maiandrei
- 4,711 mesaje
- din 20 Dec 2004
maiandrei
Remove
Remove air intake pipe (4) – see illustration "Air Ducts" in group "J".
Remove engine control unit (3) – see operation "Engine Control Unit, Remove and Install" in group "J".
Remove engine control unit bracket (2) from camshaft housing cover and exhaust gas recirculation valve.
Disconnect sheathed glow plug connectors (1) from sheathed glow plugs.
Remove bracket for alternator cable bundle (1) from exhaust gas recirculation valve and lay aside.
Remove charged air tube (3) – see illustration "Air Ducts" in group "J".
Remove lower engine compartment cover.
Remove coolant hose (2) from thermostat housing – collect coolant.
Remove exhaust gas recirculation pipe (1) from exhaust manifold and exhaust gas recirculation valve.
Remove bracket for exhaust gas recirculation pipe (2) from cylinder head and remove exhaust gas recirculation pipe.
Clean
Install
Insert exhaust gas recirculation pipe and attach to exhaust gas recirculation valve – tightening torque 44.1 Nm / 33 lbf. ft.
Attach exhaust gas recirculation pipe with new seal to exhaust manifold – tightening torque 28.4 Nm / 21 lbf. ft.
Attach bracket for exhaust gas recirculation pipe to cylinder head.
Attach coolant hose to thermostat housing.
Install lower engine compartment cover.
Install charged air tube – see illustration "Air Ducts" in group "J".
Attach bracket for alternator cable bundle to exhaust gas recirculation valve.
Connect sheathed glow plug connectors to sheathed glow plugs.
Install engine control unit bracket:
– to exhaust gas recirculation valve – tightening torque 24.5 Nm / 18 lbf. ft.
– to camshaft housing – tightening torque 9.8 Nm / 7 lbf. ft.
Install engine control unit – see operation "Engine Control Unit, Remove and Install" in group "J".
Install air intake pipe – see illustration "Air Ducts" in group "J".
Inspect
Top up cooling system – see operation "Cooling System, Top Up and Bleed " and "Cooling System, Check for Leaks " in group "J".
Preluat din TIS
Pare-se ca nu e la fel de simplu precum la Y20DTH...
Remove
Clean
Install
Inspect
Preluat din TIS
zildan
- Mesaje scrise: 65
- Masina: Astra 2001 Y1.7DTI 16V
- Cont inregistrat: 05 Jul 2006
Am curatat valva EGR la motorul de y 17dt.
A durat cateva ore bune.
Masina mea NU consuma ulei. Are 122 mii km.
Am curatat valva mai mult din curiozitate.
Asa arata din laterala:
Demontezi calculatorul
Demontezi suportul calculator
Demontezi conductele ca in postul de mai sus.
Demontezi valva EGR si vezi galeria de admisie imputita
Asa arata pe interior valva EGR imputita:
Asa arata dupa ce o cureti:
Galeria curatata arata asa:
Montajul e la fel in sens invers.
Nu recomand celor care nu au indemanare sa incerce. La motorul de 2L se curata mult mai usor.
LE:
Dupa aproape un an de ISUZU va atentionez sa verificati mai intai circuitele de vid si valvele care le comanda.
Problemele la acest motor mai mult de acolo apar.
Ultima modificare facuta de zildan la Sam 05 Mai, 2007 8:52 pm, modificat de 4 ori in total
LE:
alcaffera
- Mesaje scrise: 39
- Masina: Astra 2002 y17dt
- Cont inregistrat: 05 Apr 2006
@zildan: mufele de la ECU le-ai scos cu fisa de la baterie deconectata sau fara?
vreo imbunatatire simtitoare in functionarea motorului?
la y17dt-ul meu am observat de curand ca are niste momente cand, in clipa in care vrei sa fortezi putin si calci mai puternic acceleratia indiferent de treapta incepe sa dea niste rateuri foarte scurte (sa zic zecimi de secunda) niste intreruperi de parca ai lua niste suturi.
asta se intampla aleator numai cand este motorul cald si la turatii inte 1800-2500. la rece merge ca uns si la turatii mai mari de 2500 cald.
sa fie tot de la EGR? are cineva vreo idee.
prima oara am suspectat motorina sau vreun injector. insa motorina am schimbat-o intre timp punand in general de la OMV si Rompetrol iar injector cu functionare defectuoasa n-as prea crede, ar trebui sa se manifeste fenomenul si in primul sfert de ora pana sa se incalzeasca motorul.
A mai intalnit cineva fenomenul?
zildan
- Mesaje scrise: 65
Am scos mufele fara sa scot bateria, eu am schimbat si filtrul de motorina, asa ca e greu de spus daca de la EGR sau de la filtru, dar a revenit in parametrii masina.
Am alimentat in Grecia cu o motorina groaznica. Abia am ajuns acasa.
Acum merge bine.
Puteti face proba de functionare valva EGR scotand furtunul de vid care o actioneaza.
Acum merge bine.
- popescu iulian
- 1,400 mesaje
- din 19 Jun 2006
- Timisoara
popescu iulian
zildan
- Mesaje scrise: 65
Deci trebuie sa strangulezi furtunul mai exact.
Concluzia mea dupa ce am desfacut valva este urmatoarea:
-Testezi daca valva e blocata inchis nu se incalzeste teava metalica ce iese din galerie. (asta in primele zeci de secunde dupa ce pornesti motorul)
-Testezi daca valva e blocata deschis astfel:
strangulezi furtunul, (nu il scoti direct, daca il scoti dezechilibrezi vidul in toata masina) nu ar trebui sa se incalzeasca teava (care iese din galerie) in primele zeci de secunde cand pornesti masina, evident cu motorul rece.
Teava care iese din galerie este :
gas recirculation pipe (1) in imag de mai jos
Ultima modificare facuta de zildan la Mie 23 Aug, 2006 10:03 pm, modificat de 5 ori in total
- b82bog
- 400 mesaje
- din 19 Sep 2005
- Astra Y17DT
b82bog
- Mesaje scrise: 400
- Masina: Astra Y17DT
- Cont inregistrat: 19 Sep 2005
- BAZGANM
- 630 mesaje
- din 05 Feb 2006
- Astra 2000 y17dt
BAZGANM
- Mesaje scrise: 630
- Masina: Astra 2000 y17dt
- Cont inregistrat: 05 Feb 2006
la 1.7 este mai greut un pic! si diferente imense la functionare nu sint. a mea smucea un pic la schimbarea treptelor de viteza! acum doar ca scoate mai mult fum dupa aceasta curatare a valvei care era blocata ......oricum la cite probleme am cu ea nu imi mai dau seama.eu am refacut si lipiturile reci la calculatorul de injecti[3 la numar] si nu este nici o diferenta in functionare,este varza......
- cristivw
- 247 mesaje
- din 06 Oct 2005
- Astra 2001 Y17DT
cristivw
- Mesaje scrise: 247
- Masina: Astra 2001 Y17DT
- Cont inregistrat: 06 Oct 2005
- boditza
- 765 mesaje
- din 28 Sep 2006
- Dolj
boditza
- Mesaje scrise: 765
- Cont inregistrat: 28 Sep 2006
- King of the road
- 489 mesaje
- din 15 Apr 2004
- Mures
King of the road
- Mesaje scrise: 489
din moment ce nu avem voie sa deschidem alt topic pe aceeasi tema...
Tu crezi ca daca deschizi un topic nou pe aceeasi tema cineva o sa puna o poza sa te lamureasca pe tine ?
Nu a zis nimeni ca nu e voie dar ar fi foarte urat din partea ta sa faci asta ... iar eu o voi considera ca o jignire la adresa mea, adica tu stii ca exista deja topicul respectiv dar totusi vrei sa deschizi unul nou(bineinteles ca il voi sterge), deci iti bati joc de mine si de munca mea !
Vorbesc doar in numele meu dar sunt sigur ca si pe ceilalti moderatori i-ai deranja.
Visse- Suspendat
- 1,464 mesaje
- din 06 Jun 2005
Visse- Mesaje scrise: 1,464
- Cont inregistrat: 06 Jun 2005
Astazi am reusit sa curat si eu valva EGR , lucrerea de baza a facut-o cumnatul meu , eu doar cu un mic ajutor si cu o filmare din cand in cand pe care sper sa o pun la dispozitia celor ce o vor .Am gasit-o super jegoasa , o pasta neagra la suprafata apoi o depunere mai solida gen carbune , galeria de admisie 30 % astupata din cauza depunerilor , s-a curatat valva si galeria de admise atat cat s-a putut fara demontare , rezultat , masina trage putin mai bine [ si nu este efectul placebo ] iar cand intra in actiune turbina se simte mai bine decat inainte . Toate astea nu le faceam daca nu aveam pozele si tutorialul lui ZILDAN pentru care ii multumesc .
- roadrunner79
- 226 mesaje
- din 05 Mai 2006
- Astra 2001 Y17DT
roadrunner79
- Mesaje scrise: 226
- Cont inregistrat: 05 Mai 2006
Visse- Suspendat
- 1,464 mesaje
- din 06 Jun 2005
- roadrunner79
- 226 mesaje
- din 05 Mai 2006
- Astra 2001 Y17DT
roadrunner79
Am reusit sa curat si valva EGR. Eu am desfacut destul de multe ca sa ajung la ea (baterie + suport, filtru aer + debitmetru, calculatorul + suportul acestuia, furtunul de admisie ce merge la turbina, teava dintre intercooler si EGR, teava de recirculare a gazelor arse). Desi am dat jos atatea , operatia a durat vreo 3 ore (demontat, curatat, montat). Am gasit pe valva o pasta neagra pe care am curatat-o cu benzina. Am curatat si galeria de admisie atat cat am putut sa bag mana.
Daca se simte ceva in mersul masinii?? Nu stiu.. deocamdata e vremea urata si nu am chef de iesit din casa..
Am facut cateva poze, insa nu prea multe pt ca eram destul de negru pe maini si nu prea-mi venea sa ma apropii de aparat ..
1 - pt cum se da jos bateria si suportul am explicat aici
2 - capacul filtrului de aer + debitmetrul se desfac destul de usor (4 cleme + 2 coliere)
3 - calculatorul de injectie e prins in 4 suruburi (2 se desfac cu cheia de 10, 2 cu un imbus)
4 - suportul calculatorului este prins in 3 suruburi (1 se desface cu cheia de 10, 2 cu cheia de 12). In poza de mai jos am indicat locul unde se afla acestea.
5 - furtunul dintre filtru de aer si turbina e prins in 2 suruburi si colierul de la turbina (sagetile rosii in ultima poza)
6 - teava de admisie dintre intercooler si EGR: se desface colierul de prindere de la intercooler si inca 3 suruburi: 1 pe chiulasa si 2 la EGR (sagetiile albastre din ultima poza)
7 - teava de recirculare a gazelor arse e prinsa in 2 suruburi de galeria de evacuare si cu o piulita mare de EGR (se desface cu cheia de 30). (sagetiile galbene)
8 - valva EGR e prinsa in 2 suruburi de galeria de admisie.
Atentie cand desfaceti clemele ce tin firele prinse de furtune si suportul calculatorului sa nu le rupeti..
- Florin M
- 390 mesaje
- din 10 Dec 2006
Florin M
- Mesaje scrise: 390
- Cont inregistrat: 10 Dec 2006
- 69MED
- 113 mesaje
- din 17 Apr 2006
- Astra 2001 Y17DT
- Siret
69MED
- Mesaje scrise: 113
- Cont inregistrat: 17 Apr 2006
@zildan
@roadrunner79
pentru ambi , amindoi , multumiri multe .
Datorita voua am reusit si am desfacut valva EGR si am curatoat-o .
De mare ajutor au fost pozele voastre
As mai recomanda atentie mare la pozitia cum desfaceti calculatorul .
Pare pus invers . Deci atentie marita . NU am avut curajul sa-l pun invers .
Adica sa se vada corect K si M !
Atentie la pozele lui @roadrunner79
Inca o data multumiri .
@roadrunner79
