  3. Motoare benzină
  • larson
  • Mesaje scrise: 47
  • Masina: Astra 2004 Z16XEP
  • Cont inregistrat: 25 Sep 2013
am un opel astra H motor z16 xep ...imi tot apare cod ecn 017152 ,cine a avut acesta eroare si cum a rezolvat problema ?...multumesc.
  • reeaws
  • Mesaje scrise: 9
  • Masina: Astra 2005 Z16XEP
  • Cont inregistrat: 22 Sep 2014
P017152 System Too Lean (Bank 1)
Problema ta e data de sonda lambda 1, va trebui sa mergi la service pentru o diagnoza.La mine eroare era P0172 52 nu se stergea tot aparea si am schimbat sonda lambda 2. Atentie la sonda sa fie lambda 1, daca se dovedeste a fi defecta, la mine au pus sonda lambda 1 in loc de 2.
A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty
Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
There could be a vacuum leak downstream of the MAF sensor
Possible cracked vacuum or PCV line/connection
Faulty or stuck open PCV valve
Failed or faulty oxygen sensor (bank 1, sensor 1)
Sticking/plugged or failed fuel injector
Low fuel pressure (possible plugged/dirty fuel filter!)
Exhaust leak between engine and first oxygen sensor
  • catastefan
  • Mesaje scrise: 5,918
  • Masina: Corsa 2001 Z12XE
Pune-o pe tester si urmareste valorile oferite de sonda Lambda 1 (30 .. 950 mV) si valorile oferite de MAP.
Urmareste functionarea EGR pe tester....iti poate saraci amestecul daca ramane blocat ( pornirea e usoara ? )
Urmareste functionarea sistemului de aerisire a rezervorului de combustibil. ( canistra de carbon ....)
Si nu in ultimul rand masoara presiunea benzinei. Daca e mai mica de 3,8 bar incearca sa schimbi filtrul de benzina apoi masori iar.
Verifica temeinic etanseitatea admisiei si a evacuarii.
  • larson
  • Mesaje scrise: 47
reeaws sonda a 2 -a am schimbat-o acum vre-o 3-4 luni ,eroare apare data cu cheek enge ,cannd se aprinde ala imi apare eroarea ,cheek sta aprins ceva vreme o zi 2-3 dupa care se stinnge si tot asa.
  • larson
  • Mesaje scrise: 47
catastefan multumesc pt ajutor , nu am aici in localitate un omulet cu tester sa stie ce sa faca toti pun testerul si sterg erorile si gata , pornirea este usoara uneori ,uneori se aude uun suerat scurt la prima pornire si asta cand este mai rece afara din aceasta cauza am schimbat cureaua la alternator si tot asa face , eu nu am filtru de benzina ca la-s schimba dar este pe pompa de benzina am inteles nonviata.. las nr meu de tel poate ne auzim la telefon 0740541122 ..ms.
  • john_doe200616
  • Mesaje scrise: 447
  • Masina: Vectra 1996 X16SZR
@Iarson- nu cunosc foarte multe de modelul tau de masina, dar pe unitatea de alimentare cu combustibil ai un prefiltru montat inainte de sorbul ei din rezervor, ai un filtru langa pompa efectiva(cu rol si de regulator de presiune) din unitatea de alimentare si mai ai pe traseu inca un filtru de benzina.
La mine la Vectra, e in partea stanga a masinii, la roata din spate. Daca ai posibilitatea uita-te sub ea si vezi daca il identifici.
Arata ca in poza de mai jos.
  • larson
  • Mesaje scrise: 47
jon stiu cum arata un filtru de benzina asa ceva aveam pe astra f sub prag partea dreapta spate la h nu este am vrut sa-l cumpar si de la piese auto nu mi lau dat ,spuneau ca n-am filtru de benzina este pe pompa se scimba doar cu tot cu pompa.
  • reeaws
  • Mesaje scrise: 9
Larson in urma diagnozei din aceasta seara se pare ca eroare de care vorbeai e aceiasi si am cerut sfatul in alt post, si acelasi lucru il confirm si eu despre fltrul de benzina. Si eu am schimbat sonda lambda 2 acum aproximativ 7 luni.
  • larson
  • Mesaje scrise: 47
reeaws si cum schimbam filltrul de benzina ? este pe pompa , la nici un magazin de piese auto nu mi-au dat filtru benzina pt opel astra htoti spun ca e nonviata. 0740541122 tel meu sunama daca poti sau lasa-mi nr tau si te sun e ms.
  • catastefan
Eu încã nu înțeleg ce este nonviata... non viațã?
  • reeaws
  • Mesaje scrise: 9
Larson nu sunt atat de experimentat sa iti dau sfaturi, cred ca am vazut ceva despre pompa de benzina la astra h in alt post aici pe forum , mai rascoleste pe aici poate te lamureste cineva. Daca gasesc postul ii dau link.
  • larson
  • Mesaje scrise: 47
acum pe linga cod eroare 017152 mai am codurile 035100 si 042052 cum le rezolv ?
  • pnuhttp
  • Mesaje scrise: 89
  • Masina: Astra 2006 Z16XEP
  • Cont inregistrat: 09 Sep 2010
Salut colegu'. I-ai dat de cap? in alte posturi am vazut ca eroarea asta se leaga de admisie si EGR. Cu alte cuvine se da jos admisia si se curata canalele, la fel si EGR-ul.
  • larson
  • Mesaje scrise: 47
salut nu am mai facut nimic stau cu martorul aprins ...daca rezolvi da stire !
  • catastefan
Pentru 17152 se demonteaza admisia si se curata canalele EGR din ea. Cu aceasta ocazie se rezolva si problema cu fixarea tablei care se desprinde in ea.. Exista buletin tehnic de la Opel pentru aceasta eroare si aceasta e rezolvarea.
0351 este cod de bobina de inductie
0420 este Catalizator cu eficienta scazuta...
  • larson
  • Mesaje scrise: 47
Multumesc catastefan pentru ajutor ...cum dau de buletinul tehnic de la opel ?
  • catastefan
Daca ai TIS2000 instalat il gasesti acolo.
Daca nu uite aici
  • larson
  • Mesaje scrise: 47
multumesc frumos ,catastefan , sa vad un mecanic bun sa-i explic ce are de facut ....anul trecut am dat galeria de admisie jos ,daca stia mecanicul facea operatiunea asta !...tot eu am insistat sa o dea jos sa o curete mama lor de macanici !
  • big_electro61
  • Mesaje scrise: 4,492
  • Masina: Astra 2008 Z13DTH
Daca tot esti nemultumit de mecanici,de ce nu executi dumneata operatiunea corect...? Implica doar demontare-montare si curatarea respectiva. Ia-o ca pe o provocare sau poate nu te injosesti sa faci asemenea munci...,situatie in care se schimba datele problemei!
  • larson
  • Mesaje scrise: 47
big_electro61, nu fur painea de la gura nimanui fiecare cu meseria lui corect ?..daca tu consideri asta injosire atunci cersitul ar fi parfum !
dezvolta datele problemei si nu critica omul inainte sa-l cunosti !
  3. Motoare benzină
