larson
- Mesaje scrise: 49
- Masina: Astra 2004 Z16XEP
- Cont inregistrat: 25 Sep 2013
reeaws
- Mesaje scrise: 9
- Masina: Astra 2005 Z16XEP
- Cont inregistrat: 22 Sep 2014
P017152 System Too Lean (Bank 1)
Problema ta e data de sonda lambda 1, va trebui sa mergi la service pentru o diagnoza.La mine eroare era P0172 52 nu se stergea tot aparea si am schimbat sonda lambda 2. Atentie la sonda sa fie lambda 1, daca se dovedeste a fi defecta, la mine au pus sonda lambda 1 in loc de 2.
A code P0171 may mean that one or more of the following has happened:
The MAF (Mass Air Flow) Sensor is dirty or faulty
Note: The use of "oiled" air filters may cause the MAF to become dirty if the filter is over-oiled. There is also an issue with some vehicles where the MAF sensors leak the silicone potting material used to protect the circuitry.
There could be a vacuum leak downstream of the MAF sensor
Possible cracked vacuum or PCV line/connection
Faulty or stuck open PCV valve
Failed or faulty oxygen sensor (bank 1, sensor 1)
Sticking/plugged or failed fuel injector
Low fuel pressure (possible plugged/dirty fuel filter!)
Exhaust leak between engine and first oxygen sensor
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
- Mesaje scrise: 5,916
- Masina: Corsa 2001 Z12XE
Pune-o pe tester si urmareste valorile oferite de sonda Lambda 1 (30 .. 950 mV) si valorile oferite de MAP.
Urmareste functionarea EGR pe tester....iti poate saraci amestecul daca ramane blocat ( pornirea e usoara ? )
Urmareste functionarea sistemului de aerisire a rezervorului de combustibil. ( canistra de carbon ....)
Si nu in ultimul rand masoara presiunea benzinei. Daca e mai mica de 3,8 bar incearca sa schimbi filtrul de benzina apoi masori iar.
Verifica temeinic etanseitatea admisiei si a evacuarii.
larson
- Mesaje scrise: 49
larson
- Mesaje scrise: 49
catastefan multumesc pt ajutor , nu am aici in localitate un omulet cu tester sa stie ce sa faca toti pun testerul si sterg erorile si gata , pornirea este usoara uneori ,uneori se aude uun suerat scurt la prima pornire si asta cand este mai rece afara din aceasta cauza am schimbat cureaua la alternator si tot asa face , eu nu am filtru de benzina ca la-s schimba dar este pe pompa de benzina am inteles nonviata.. las nr meu de tel poate ne auzim la telefon 0740541122 ..ms.
- john_doe200616
- 447 mesaje
- din 24 Feb 2015
- Vectra 1996 X16SZR
john_doe200616
- Mesaje scrise: 447
- Masina: Vectra 1996 X16SZR
- Cont inregistrat: 24 Feb 2015
@Iarson- nu cunosc foarte multe de modelul tau de masina, dar pe unitatea de alimentare cu combustibil ai un prefiltru montat inainte de sorbul ei din rezervor, ai un filtru langa pompa efectiva(cu rol si de regulator de presiune) din unitatea de alimentare si mai ai pe traseu inca un filtru de benzina.
La mine la Vectra, e in partea stanga a masinii, la roata din spate. Daca ai posibilitatea uita-te sub ea si vezi daca il identifici.
Arata ca in poza de mai jos.
larson
- Mesaje scrise: 49
reeaws
- Mesaje scrise: 9
larson
- Mesaje scrise: 49
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
reeaws
- Mesaje scrise: 9
larson
- Mesaje scrise: 49
pnuhttp
- Mesaje scrise: 87
- Masina: Astra 2006 Z16XEP
- Cont inregistrat: 09 Sep 2010
larson
- Mesaje scrise: 49
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
Pentru 17152 se demonteaza admisia si se curata canalele EGR din ea. Cu aceasta ocazie se rezolva si problema cu fixarea tablei care se desprinde in ea.. Exista buletin tehnic de la Opel pentru aceasta eroare si aceasta e rezolvarea.
0351 este cod de bobina de inductie
0420 este Catalizator cu eficienta scazuta...
larson
- Mesaje scrise: 49
- catastefan
- 5,916 mesaje
- din 21 Jan 2012
- Corsa 2001 Z12XE
catastefan
larson
- Mesaje scrise: 49
big_electro61- Suspendat
- 4,493 mesaje
- din 24 Oct 2008
- Astra 2008 Z13DTH
big_electro61- Mesaje scrise: 4,493
- Masina: Astra 2008 Z13DTH
larson
- Mesaje scrise: 49
