- THRUSTMASTER
- 83 mesaje
- din 07 Feb 2020
- Zafira Tourer 2013 B16DTH
THRUSTMASTER
- Mesaje scrise: 83
- Masina: Zafira Tourer 2013 B16DTH
- Cont inregistrat: 07 Feb 2020
https://www.championlubes.co...fba4f55dd527dbcca
Rog daca stiti sa imi confirmati daca datele sunt corecte sau poate stiti voi un site mai bun.
Toate bune.
MODEL: Zafira Tourer 2013
MOTOR: B16DTH
CHanis
- Mesaje scrise: 89
- Masina: Zafira Tourer 2014 B16DTH
- Cont inregistrat: 03 Feb 2020
- THRUSTMASTER
- 83 mesaje
- din 07 Feb 2020
THRUSTMASTER
- Mesaje scrise: 83
'' The gearbox is refilled with 2.5 litres of Fuchs Titan Race SRG gearbox oil. Typically we find that the manufactures do not put enough oil in the gearbox from the factory, so we refill with the correct amount, and it is important to add this to your service schedule and replace the oil annually, refilling with 2.2 Liters (0.3 will remain in the gearbox when drained) ''
http://www.wgmotorworks.co....0-gearbox-clutch/
Care e adevarul ?
CHanis
- Mesaje scrise: 89
- IonutN
- 288 mesaje
- din 19 Jul 2007
IonutN
- Mesaje scrise: 288
- Cont inregistrat: 19 Jul 2007
Ai link aici: https://uk-selector.eame.mob...e=distributor-pvl
sau: http://www.gmdexos.com/brands/dexos2/index.html
O zi buna
- THRUSTMASTER
- 83 mesaje
- din 07 Feb 2020
THRUSTMASTER
- Mesaje scrise: 83
Pentru schimbul de ulei motor si filtre :
http://www.youtube.com/watch?v=BgxXEvRQk2s
Pentru schimb ulei cutie viteze :
http://www.youtube.com/watch?v=QWtaLQHn4Ho
Cantitatea si tipul de ulei difera de la model la model dar principiul este acelasi la toate. Fiecare poate sa vina cu completari. Numai bine.
- THRUSTMASTER
- 83 mesaje
- din 07 Feb 2020
THRUSTMASTER
- Mesaje scrise: 83
Impresii dupa primii 100 km: motorul are un mers mai rotund si mai putin zgomotos, inainte parca auzeam lantul cand apasam usor acceleratia si cand opream motorul , sunet ce a disparut. Legat de cutia de viteze acum intra mai usor in viteza si am avut un moment cand trebuia sa bag a 3 -a si nu am mers pana la capat, fiind nehotarat iar schimbatorul a alunecat singur in viteza a 3-a parca stiind ce vroiam sa fac. Iar legat de aditiv am ales sa il pun pentru curatarea sistemului de alimentare si ptr ca aveam o usoara tremurare la relantiu si un raspuns intarziat la pedala iar acum totul e ok. Poate e placebo legat de ultima chestie dar inainte la relantiu aveam consum instant variabil de la 0.5 la 0 7 iar acum sta fix la 0.5. Numai bine
CHanis
- Mesaje scrise: 89
jocher
- Mesaje scrise: 5
- Masina: Astra 2014
- Cont inregistrat: 14 Nov 2020
Datele: am schimbat uleiul in cutia de viteze, am pus înauntru 1.8 litri conform date din program de la service multimarca pentru acest cod motor A14NEL ( 1.4 turbo benzina 120 CP). Dar din cutie au iesit numai 1350 ml.
La reprezentanta Opel de unde am luat masina, mi au spus ca intra 2.2 litri. ( nu am schimbat la ei pentru ca erau prea scumpi). Pe link-urile postate mai sus vad la fel, 2.2 litri.
Intrebarea mea este, stie cineva precis cati litri intra in cutie? ( in manual nu scrie nimic referitor la asta).
Va multumesc anticipat pentru rãspunsuri.
- mikyboy
- 5,734 mesaje
- din 08 Dec 2006
- Insignia 2014 A20TDH
mikyboy
- Mesaje scrise: 5,734
jocher
- Mesaje scrise: 5
Alte detalii ar fi ca masina are la bord 55k km ( reali) si despre cutie mecanicul spune ca nu se vad pierderi si nici nu pare desfacuta. Ramane misterul celor 1350 ml ulei scosi din ea ( de ce numai atat? ) Masina in mers se comporta ''ca noua'' cu cei 1350 ml cat avea in cutie.
- mikyboy
- 5,734 mesaje
- din 08 Dec 2006
mikyboy
ori vorbim alta limba sau tu nu stii ce detalii sa ceri/oferi: ai scris mai sus doar tipul de motor nu si tipul de cutie (asa cum spuneam pe acest motor au fost puse si alte cutii de viteza cum sunt de exemplu automate) ca lumea de pe forum sa iti spuna daca au informatia cat ulei este necesar la tipul tau de cutie (probabil nu stii ce tip de cutie ai, codul cutiei ma refer)...
acum cei de la reprezentanta ti-au spus ca intra 2.2 in total dar este posibil ca o parte din ulei tu sa nu il poti scurge (depinde de tipul cutiei) asa cum de exemplu la o cutie automata Aisin are 7l in total dar poti scurge doar vreo 3l...
sper ca m-am facut inteles acum
P.S. cat despre ideea de ansamblu, nu are cum sa isi dea seama lumea atata timp cat tu ai pus doar tipul motorului nu si al cutiei asa cum am scris eu mai sus
jocher
- Mesaje scrise: 5
- mikyboy
- 5,734 mesaje
- din 08 Dec 2006
mikyboy
cat despre faptul ca aveai putin ulei in cutie, daca nu ai masina de noua, nu ai de unde sa stii daca nu i-a fost schimbat vreun semering pentru ca curgea si nu a mai fost completat cu ulei sau schimbat uleiul...
deci afla codul cutiei, gasesti exact cat ulei intra in cutie, completezi peste cei 1.8 l deja pusi si gata, problema rezolvata. succes
P.S. nu ai spus nici despre ce masina este vorba ca si tip: Opel ....
jocher
- Mesaje scrise: 5
@mikyboy, multumesc frumos pentru indicatii, va doresc tuturor o primavara frumoasa.
- mikyboy
- 5,734 mesaje
- din 08 Dec 2006
mikyboy
Ca sfat, la Opel la cutie sa folosesti mereu doar ulei original si poti sa il schimbi (fiind manuala) odata la 5 ani maxim (recomandabil 3 ani). De asemenea nu uita sa schimbi odata la 2 ani lichidul de frana si antigelul.
jocher
- Mesaje scrise: 5
Va doresc sanatate.
- THRUSTMASTER
- 83 mesaje
- din 07 Feb 2020
THRUSTMASTER
- Mesaje scrise: 83
Am pus initial ulei 5W30 5L si vara trecuta motorul a fost foarte zgomotos din cauza noii noastre clime tropicale asa zisa temperat continentala (temperaturi de pana la 40grade la umbra) asa ca anul asta am pus 0w40 si vreau sa va spun ca motorul merge perfect, toarce. Recomand.
La urmatorul schimb de ulei pe langa uleiul 0W40 voi adauga si aditivul Prolong.
Drumuri bune va doresc.
- FMarian897
- 21 mesaje
- din 23 Aug 2017
FMarian897
- Mesaje scrise: 21
- Cont inregistrat: 23 Aug 2017
- THRUSTMASTER
- 83 mesaje
- din 07 Feb 2020
THRUSTMASTER
- Mesaje scrise: 83
Legat de uleiul de cutie aici un test de vascozitate intre diferite valori la -30 de grade:
http://www.youtube.com/watch?v=Wm2s_7pfmW8
In aceasta vara voi pune ulei + aditiv.
Uleiul aici : https://www.uleidemotor.com/triax-1
Aditivul aici : https://www.uleidemotor.com/...ransmisii-cu-afmt
Eu asta pun in masina mea, nu fac reclama. Voi puneti ce vreti.
Anul trecut in primavara am fost in service sa imi schimbe distributia si ambreiajul si mi-au pus alt ulei iar iarna aceasta a fost cam teapan schimbatorul timp de cateva minunte pana se incalzea.
Drumuri bune sa aveti
