- adriancean
- 166 mesaje
- din 24 Aug 2007
- Corsa 2001 Z10XE
- Hunedoara
adriancean
- Mesaje scrise: 166
- Masina: Corsa 2001 Z10XE
- Cont inregistrat: 24 Aug 2007
- BV-31STE
- 523 mesaje
- din 22 Feb 2006
- Insignia 2010 A20DTH
BV-31STE
- Mesaje scrise: 523
- Cont inregistrat: 22 Feb 2006
- dancuciureanu
- Moderator
- 16,457 mesaje
- Agila 2001 Z10XE + Z12XE
dancuciureanu
- Mesaje scrise: 16,457
- umblaretz
- 975 mesaje
- din 20 Jan 2008
- Corsa 2002 Z12XE
umblaretz
- Mesaje scrise: 975
- Masina: Corsa 2002 Z12XE
- Cont inregistrat: 20 Jan 2008
- dancuciureanu
- Moderator
- 16,457 mesaje
dancuciureanu
- scanx
- 679 mesaje
- din 07 Jun 2009
- Corsa 2001 Z12XE
scanx
- Mesaje scrise: 679
- Masina: Corsa 2001 Z12XE
- Cont inregistrat: 07 Jun 2009
- umblaretz
- 975 mesaje
- din 20 Jan 2008
- Corsa 2002 Z12XE
umblaretz
grosu29
- Mesaje scrise: 16
- Cont inregistrat: 05 Mar 2008
Salutare; acum chiar am ajuns intr-un impas.
La o zi dupa ce am schimbat debitmetrul cu unul nou bosch 0280218031 si sonda lambda postcatalizator am stocate 3 erori (fara a mi se aprinde inca martor luminos) pe:
Corsa c 2001 Z10XE.
P0100 Mass or volume air flow circuit high input
P0100 Mass or volume air flow circuit low input
P0100 Mass or volume air flow circuit range/performance problem
P0110 Intake Air Temperature Circuit High Input
P0110 Intake Air Temperature Circuit Low Input
P0141 O2 Sensor Heater Circuit High Voltage (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Low Voltage (Bank 1 Sensor 2)
P0141 O2 Sensor Heater Circuit Open (Bank 1 Sensor 2)
P0141 O2 sensor heater circuit malfunction (Bank 1 Sensor 2)
Am facut resetare coduri eroare.
Any ideas? sper fara a mai inlocui alte componente.
Corsa c 2001 Z10XE.
- pascaru_val
- 1,430 mesaje
- din 07 Jun 2005
- Astra 2006 Z17DTL
pascaru_val
- Mesaje scrise: 1,430
- Masina: Astra 2006 Z17DTL
- Cont inregistrat: 07 Jun 2005
- gcom61
- 935 mesaje
- din 25 Mai 2008
- Meriva 2005 z14xep
- Giurgiu
gcom61
- Mesaje scrise: 935
- Masina: Meriva 2005 z14xep
- StefanTolos
- 4,224 mesaje
- din 23 Nov 2007
- Corsa 2018 B12XER
StefanTolos
- Mesaje scrise: 4,224
- Masina: Corsa 2018 B12XER
- scanx
- 679 mesaje
- din 07 Jun 2009
- Corsa 2001 Z12XE
scanx
grosu29
- Mesaje scrise: 16
- scanx
- 679 mesaje
- din 07 Jun 2009
- Corsa 2001 Z12XE
scanx
grosu29
- Mesaje scrise: 16
- scanx
- 679 mesaje
- din 07 Jun 2009
- Corsa 2001 Z12XE
scanx
- pascaru_val
- 1,430 mesaje
- din 07 Jun 2005
- Astra 2006 Z17DTL
pascaru_val
- roberto07man
- 2 mesaje
- din 29 Mar 2009
- Corsa 1998 z10exp
- Hunedoara
roberto07man
- Mesaje scrise: 2
- Masina: Corsa 1998 z10exp
- Cont inregistrat: 29 Mar 2009
salut ! am achizitionat de ceva vreme un opel corsa cu mot 1000 cm 12v si am avut probleme cu debitmetrul l-am schimbat si surpriza a mers f bine timp de vreo luna dupa care aceleasi sintome adik da in nas si se tureaza greu cand plec de pe loc intarzie acceleratia!
pe tester a-mi spune tensiune insuficienta la debitmetru unde ar trebui sa ma uit sau ce ar trebuii facut !
are cineva idee sau a patit cineva asa ceva?astept un sfat de la cunoscatori!multumesc!
Titlu,descriere.....cautare.
edit by Stefan Tolos.
17.08.2011 03:08:09
Bine ati venit pe forum,va pun la dispozitie cateva recomandari pentru evitarea neplacerilor,
CAUTA si vei gasi , Ce trebuie sa am in vedere pe acest forum ? si Regulament General
edit by StefanTolos
17.08.2011 03:08:16
17.08.2011 03:08:09
edit by StefanTolos
17.08.2011 03:08:16
- Alex-Carol
- 158 mesaje
- din 26 Jun 2010
- Corsa 1998 x10xe
- Mures
Alex-Carol
- Mesaje scrise: 158
- Masina: Corsa 1998 x10xe
- Cont inregistrat: 26 Jun 2010
- zahariaconst
- 71 mesaje
- din 31 Aug 2010
- Corsa 2003 Z12XE
zahariaconst
- Mesaje scrise: 71
- Masina: Corsa 2003 Z12XE
- Cont inregistrat: 31 Aug 2010
Vreau sa fac o diagnoza la cineva priceput din Ploiesti care sa citeasca/interpreteze valorile intr-un mod profesionist.
Pana acum am facut 2 diagnoze, dar dupa inlocuirea unor piese destul de scumpe(sonda Lambda 2, de exemplu), rezultatul este ca inainte!Daca stie cineva un meserias in diagnoze bun, la Ploiesti, sa-mi zica!Multumesc anticipat!
